monty221ti Posted August 7, 2011 Report Share Posted August 7, 2011 (edited) Hi there, Got my Echo pure Sl From trialaction.dk today, and it's just awesome. Pics: https://picasaweb.google.com/113279892950671159115/7Aug2011 Will add more pictures tomorrow. Spec: Echo Pure SL 2011 Spec: Frame and Forks: - Frame: Echo Pure SL 2011 - Forks: Echo SL 2011, Disc Only Wheels: - Front hub: Echo TR Disc, with Titanium axle bolts - Rear hub: Echo TR 135mm, with Titanium axle bolts - Front rim: Echo TR - Rear rim: Echo TR - Spokes: Echo Superlight - Nipples: Echo Alloy - Rim tape: Echo, white - Inner tube (front): Echo Unboxed - Inner tube (rear): Echo Unboxed - Front tyre: Kenda Small Block 8, 2.1" - Rear tyre: Kenda Kinetics Brakes: - Front brake: Echo TR Hydraulic Disc, 180mm - Rotor bolts: Echo Titanium - Caliper bolts: Echo Titanium - Rear brake: Echo TR Hydraulic Rim Brake - Brake bolts: Echo Titanium Drivetrain: - Cranks: Echo SL, 170 ISIS - Freewheel: Echo Titanium, 18t - Chain: Echo SL, 3/32" - Rear Sprocket: Echo Titanium 15T Screw On - Pedals: Echo SL Platform - Bottom bracket: Echo Urban ISIS, Titanium axle - Bashring: Echo SL, Black Steering: - Headset: Echo SL, with Titanium bolt - Stem: Echo TR 20", with Titanium bolts - Grips: Echo Rubber, Clear - Handlebars: Echo SL Geometry: Wheelbase: 1085mm Chainstay Length: 380mm BB Rise: 55mm Head Angle: 72 degrees Centre of BB shell to top centre of head tube: 660mm Weight: 9.06kg! Edited August 31, 2011 by monty221ti Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted August 7, 2011 Report Share Posted August 7, 2011 Oops... there's nothing to see here. Either you do not have access to these photos, or they don't exist at this web address. Please contact the owner directly to gain access. Quote Link to comment Share on other sites More sharing options...
monty221ti Posted August 7, 2011 Author Report Share Posted August 7, 2011 Oops... there's nothing to see here. Either you do not have access to these photos, or they don't exist at this web address. Please contact the owner directly to gain access. fixed. Quote Link to comment Share on other sites More sharing options...
Yorkshire Dale Posted August 7, 2011 Report Share Posted August 7, 2011 fixed. the stem is too long!! Quote Link to comment Share on other sites More sharing options...
monty221ti Posted August 8, 2011 Author Report Share Posted August 8, 2011 i tried it with the stem that is ment to be there, but i didnt like it, couldn't make taps and stuff, then i tried the 20" stem and i could do all the things. i like it that way, lokks better to. Quote Link to comment Share on other sites More sharing options...
robintrial Posted August 8, 2011 Report Share Posted August 8, 2011 cool bike + if you are a big guy you need a 20"stem on a 26" best comfort Quote Link to comment Share on other sites More sharing options...
monty221ti Posted August 9, 2011 Author Report Share Posted August 9, 2011 (edited) yeah i am aproc 1.80m så i am a bit to tall for the 26" stem. Edit: Anyone knows how i get my bashring to sit in the right place, it moved behind the cranks so i need to turn it back. Edited August 9, 2011 by monty221ti Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted August 9, 2011 Report Share Posted August 9, 2011 I thought it was in a bit of an odd place haha. I guess your right foot forward... put something between the crank and bashring as you tighten it up. Quote Link to comment Share on other sites More sharing options...
monty221ti Posted August 9, 2011 Author Report Share Posted August 9, 2011 thanks, i will try that, now i only need to loosen the freewheel, i have the cyclo tool and it doesnt fit so good, but thanks! Quote Link to comment Share on other sites More sharing options...
Bigman Posted August 11, 2011 Report Share Posted August 11, 2011 Looks realy smart, these new echo builds are pretty sweet! Only thing I would recomend is to rotate the bars back abit, they are WAY too far forward! Adam Quote Link to comment Share on other sites More sharing options...
monty221ti Posted August 11, 2011 Author Report Share Posted August 11, 2011 (edited) Thanks Adam. i Will try to rotate them tommorrow. Edit: Can anyone tell me, how do i waterbleed my echo tr rim brake? Me and a mate tried to do it and ended up doing it 7-8 times, we just couldnt bleed it without getting air in. We were bleeding it with ?syringes? Would it be better with a bathbleed? Bath bleeded it and works sick now, just ordered the tnn be-green pads and bealay refills, gonna be good with some proper pads! Edited August 14, 2011 by monty221ti Quote Link to comment Share on other sites More sharing options...
monty221ti Posted August 31, 2011 Author Report Share Posted August 31, 2011 check out the new pics. got the be-green pads on now and they are awesome. i need a new rear tyre as i man constantly pinch-flatting on this shitty kende kinetics Quote Link to comment Share on other sites More sharing options...
