Sprocket Derails Chian
JDStrials
the front sprocket , rear sprocket and derailier should always by as strait as possible with each other, specialy if you are using a derailier. so check that. im guessing you are using a single speed set up? if the angles are different thats your problem the chain should run in a nice strait line otherwise you get a tight spot were it grips, skips or the derailier and bingo the chain is off.
no, im currently using the standard six speed gears that come with the onza cleaner. but the chain going to the derailor (sorry about spelling)is at a different angle than from what it is being picked up by the front sprocket.
would single speeding it potentially solve this problem?
thanks for the reply
Jack
Edited by JDStrials
