cardenas_26trials Posted July 31, 2011 Report Share Posted July 31, 2011 Anybody knows how much does the frame weight? looked for it in every place and couldn't find it . I would be very pleased if somebody could tell me Cheers, Esteban Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 31, 2011 Report Share Posted July 31, 2011 - Fully constructed from tough U6 aluminium, as proven by Echo and ZOO, with super-stiff CNC machined Chain and Seatstay yokes. - Thicker tubes than most frames for increased frame life and dent resistance, also makes the frame stiffer for superb power transfer! - Bracing plates between the top and down tubes also increase front end stiffness, perfect for getting the most out of the bike when front tapping and hooking. - Takes standard 1 1/8" headset. - Dedicated 4-bolt Magura mounts as standard on the frame, with built in booster for maximum brake stiffness and control. - Bashplate-less design offers excellent weight saving benefits. - Sculpted 3D CNC machined one-piece chainstay/BB yoke offers excellent tyre and freewheel clearance and help create a super strong frame. - Integrated chain-stop boss on the driveside chainstay yoke prevents unwanted chain stretching and/or damage from obstacles. - Toptube and downtube gussets at the headtube join provide excellent strength and stiffness. - Unique CNC sculpted dropouts offer excellent strength, weld contact area and looks. - Ultra compact frame design offers excellent stand over clearance with a frame height of just 4.5". - Brushed aluminium and lacquered finish resists scratches and looks classy! - 110mm long head tube. - weight 1.811kg/3.9lbs Geometry Wheelbase: Short 1000mm, Long 1030mm Chainstay Length: 362mm BB Rise: 60mm Head Angle: 72 degrees Centre of BB shell to top centre of head tube: Short 595mm (23.5"), Long 615mm (24.25") Quote Link to comment Share on other sites More sharing options...
F.N.G Posted July 31, 2011 Report Share Posted July 31, 2011 Where did you find this? Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 31, 2011 Report Share Posted July 31, 2011 The magic search bar, just searched for posts made between the start of 2005 and end of 2006. Quote Link to comment Share on other sites More sharing options...
Greetings Posted July 31, 2011 Report Share Posted July 31, 2011 That's fairly light for something which proved to be virtually indestructable. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted July 31, 2011 Report Share Posted July 31, 2011 That's fairly light for something which proved to be virtually indestructable. This is true. Mate of mine has an 07 Typhoon and is still going strong with no cracks or dents. Has seen some big riding too. Deng NEED to bring out frames like these again Quote Link to comment Share on other sites More sharing options...
cardenas_26trials Posted July 31, 2011 Author Report Share Posted July 31, 2011 (edited) - Fully constructed from tough U6 aluminium, as proven by Echo and ZOO, with super-stiff CNC machined Chain and Seatstay yokes. - Thicker tubes than most frames for increased frame life and dent resistance, also makes the frame stiffer for superb power transfer! - Bracing plates between the top and down tubes also increase front end stiffness, perfect for getting the most out of the bike when front tapping and hooking. - Takes standard 1 1/8" headset. - Dedicated 4-bolt Magura mounts as standard on the frame, with built in booster for maximum brake stiffness and control. - Bashplate-less design offers excellent weight saving benefits. - Sculpted 3D CNC machined one-piece chainstay/BB yoke offers excellent tyre and freewheel clearance and help create a super strong frame. - Integrated chain-stop boss on the driveside chainstay yoke prevents unwanted chain stretching and/or damage from obstacles. - Toptube and downtube gussets at the headtube join provide excellent strength and stiffness. - Unique CNC sculpted dropouts offer excellent strength, weld contact area and looks. - Ultra compact frame design offers excellent stand over clearance with a frame height of just 4.5". - Brushed aluminium and lacquered finish resists scratches and looks classy! - 110mm long head tube. - weight 1.811kg/3.9lbs Geometry Wheelbase: Short 1000mm, Long 1030mm Chainstay Length: 362mm BB Rise: 60mm Head Angle: 72 degrees Centre of BB shell to top centre of head tube: Short 595mm (23.5"), Long 615mm (24.25") Thanks buddy! really looked for it everywhere, thanks again cheers! Edited July 31, 2011 by cardenas_26trials Quote Link to comment Share on other sites More sharing options...
