trialsalot Posted July 30, 2011 Report Share Posted July 30, 2011 (edited) So, Just fitted an sd7 and yellow heatsink and I'm struggling with setting them up. I'm running neon adapters on some echo urbans with backward mounts and a koxx single wall drilled rim. Basically I cant get the pads to sit square using the conical washers even when swapped round to use the differing sizes.Even when I remove all washers they wont square up. Is it a possibility my rim is too wide or spacings somehow wrong. Ali...I'd love your help on this one fella! Suggestions? Edited July 30, 2011 by trialsalot Quote Link to comment Share on other sites More sharing options...
Ali C Posted July 30, 2011 Report Share Posted July 30, 2011 Ali...I'd love your help on this one fella! Suggestions? you failed by not getting vee forks! Magura forks with adaptors AND being backwards is total fail. It will never be as powerful as dedicated forks, the cable will get in the way and it won't be as stiff. You also failed by getting some heatsink pads, they are pretty dam fat! I am going to suggest a couple of options, but unfortunately they all involve spending money. 1) get some vee forks. Seriously, if you can, DO IT! 2) get some TNN LGV pads, they are super thin and will save some space, if you can afford it do this as well as option one. 3) if you don't want to spend much money, get some adaptors with more adjustment like Onza, should give enough room then. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted July 30, 2011 Report Share Posted July 30, 2011 As ali said, get some vee forks, just happens i have some viz Vee forks forsale... Quote Link to comment Share on other sites More sharing options...
