Laurence--Trials Posted July 29, 2011 Report Share Posted July 29, 2011 I brought some of the monty brake spray from tarty, received it this morning followed the instructions in the can and put it on, span the wheel fast and sprayed it round and the only thing the spray has helped with is me falling on my arse more offen. Am i applying it wrong? i've come home given my rear rim/pads a VERY good clean and im willing to try the spray a cupple more times. So any tips for using this stuff or is it just complete shit? - in a can. Quote Link to comment Share on other sites More sharing options...
kaybs41282 Posted July 29, 2011 Report Share Posted July 29, 2011 I've used it a few times...it's ok but you only need a very small amount or it locks your brakes. Quote Link to comment Share on other sites More sharing options...
Revolver Posted July 29, 2011 Report Share Posted July 29, 2011 Use a grind, for christ's sake. This goes for everyone using tar or anything else on their brakes. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 I've used it a few times...it's ok but you only need a very small amount or it locks your brakes. I found it just made mine terrible. I'll try using a tiny amount though. Use a grind, for christ's sake. This goes for everyone using tar or anything else on their brakes. I dont have a grinder, also dad seems know everything about trials and you can only grind your rim once then you have to get a new one (detect the sarcasm) Quote Link to comment Share on other sites More sharing options...
Revolver Posted July 29, 2011 Report Share Posted July 29, 2011 Well, go round a mate's. You can't really tell how many grinds a wheel has so he'll never know. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 that stuff is SHIT. however i recently went out side, held the rear brake and pushed back it did seeeeem.. like it was getting better. If not I'll clean the rim and should have my ZOO! pads with me sometime next week. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 29, 2011 Report Share Posted July 29, 2011 What pads? Photos of setup? Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 What pads? Photos of setup? One heatsink red and one plasmic (spelling?) clear pad (due to my other heatsink red having no material left, not sure why though, they came like that when i brought the bike), on dear grind, some plastic booster (does the job though) 4 finger lever on 05 magura. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 29, 2011 Report Share Posted July 29, 2011 Hmm. Any photos of the setup? Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 No sorry, parents are on holiday so they have the camera. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 I was wondering if it was the dead grind that caused me to have a bad rear brake cause i put some on my mates smooth bmx rim and it worked perfectly and made his brakes really good (for the first time) so he was pleased, unlike me Quote Link to comment Share on other sites More sharing options...
bagre15 Posted July 29, 2011 Report Share Posted July 29, 2011 Use a grind, for christ's sake. This goes for everyone using tar or anything else on their brakes. I use a light grind with a bit of tar. Locks as hell Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted July 29, 2011 Report Share Posted July 29, 2011 The way I use it is - Spray 4 little dots at each side of the rim (top bottom left and right) Cycle about for 10 seconds or so holding the brake in to make it spread lay it on the ground to let it dry for about 20 seconds Pick up your bike and use your epic brake I do it this way, makes it awesome. I was wondering if it was the dead grind that caused me to have a bad rear brake cause i put some on my mates smooth bmx rim and it worked perfectly and made his brakes really good (for the first time) so he was pleased, unlike me My grind is fairly dead and the brake spray worked great Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 Once the stuff i've put on has worn off i'll try that kieran, thanks! Although i dont have much faith in this stuff. I was expecting amazing braking (bite, hold AND sound) and i get the oposite with a high pitched failing squeak. , Quote Link to comment Share on other sites More sharing options...
Grant-MacD Posted July 29, 2011 Report Share Posted July 29, 2011 Once the stuff i've put on has worn off i'll try that kieran, thanks! Although i dont have much faith in this stuff. I was expecting amazing braking (bite, hold AND sound) and i get the oposite with a high pitched failing squeak. , I think it's the fact that you have it on a dead grind. I have the same problem it works perfect on the rear with the same pads and with no grind but it just won't work on my front with a dead grind. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 I think it's the fact that you have it on a dead grind. I have the same problem it works perfect on the rear with the same pads and with no grind but it just won't work on my front with a dead grind. Ahh i see, i'll have to wait until its smooth i guess. Cheers for that grant Atleast i know whats going on now. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted July 29, 2011 Report Share Posted July 29, 2011 If your not allowed the use of a grinder, I seriously recommend Heatsinks CNC Yellows. Work so so well on dead grinds. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted July 29, 2011 Author Report Share Posted July 29, 2011 I got some £5 onza pads and from what i'm used to they're insane and perfect for what i need, apart from the fact i like a quiet front brake for going from A to B but other than that they're perfect. For the rear i've ordered some ZOO! pads which people like CLS used so we'll see how they work. If they don't do it for me then heatsink yellows CNC it is!! Quote Link to comment Share on other sites More sharing options...
Revolver Posted July 29, 2011 Report Share Posted July 29, 2011 I use a light grind with a bit of tar. Locks as hell I use a light grind and good pads. 'Locks as hell'. Quote Link to comment Share on other sites More sharing options...
bagre15 Posted July 30, 2011 Report Share Posted July 30, 2011 I use a light grind and good pads. 'Locks as hell'. I use CNC heatsink yellows, and I tried to ride without tar, but the brakes didn't locked very well. The pads were set square. I think that the problem is that my grind was diagonally, next time I'll try to grind more vertically Quote Link to comment Share on other sites More sharing options...
kaybs41282 Posted July 30, 2011 Report Share Posted July 30, 2011 I gave up and got a grind... Better and quieter! Quote Link to comment Share on other sites More sharing options...
Revolver Posted July 30, 2011 Report Share Posted July 30, 2011 I use CNC heatsink yellows, and I tried to ride without tar, but the brakes didn't locked very well. The pads were set square. I think that the problem is that my grind was diagonally, next time I'll try to grind more vertically WAHT, I use those pads and mine is sicks. Yo, you've gotta grind in one direction only. Scrape the grinder in one direction, lift it off and move it back, instead of colouring it in both ways with the grinder. Dig? 1 Quote Link to comment Share on other sites More sharing options...
bagre15 Posted July 31, 2011 Report Share Posted July 31, 2011 WAHT, I use those pads and mine is sicks. Yo, you've gotta grind in one direction only. Scrape the grinder in one direction, lift it off and move it back, instead of colouring it in both ways with the grinder. Dig? I will regrind it tomorrow, but is there a correct direction to grind? Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted July 31, 2011 Report Share Posted July 31, 2011 I will regrind it tomorrow, but is there a correct direction to grind? Clockwise i think Quote Link to comment Share on other sites More sharing options...
MonsieurMonkey Posted July 31, 2011 Report Share Posted July 31, 2011 Clockwise i think Think about that. Quote Link to comment Share on other sites More sharing options...
