Any Troubles With Echo Tr Clamps?
Blake
As above, face your brake mounts. If you're running a rim which doesn't have paralell sidewalls like TryAll or Trialtech, you'll need to wait till the pads wear down at an angle. This is best done with a harsh rim grind, but with a hard pad compound it can take quite a while for the pads to adjust.
Either way, the TR system is the future. Results in a much stiffer brake lever.
