Hope Trial Break Bolts
Jon E Cash
I did a search but couldn't find any info.
I need to attach a hope trial rear disc brake to a Zoo! Lynx frame and I'm not sure which bolts I need to mount the calliper on the frame.
I think it's either m6x20 or the m6x18? Does anyone know? Thanks
Edit: Just realised I spelt it break >_<
Edited by Jon E Cash
I used m6x18 on the rear of my echo 24 urban, worst comes to it, get the m6x20 the trial fit them for clearance when they arrive and if they are too long, file them to suit. Saves getting m6x18 and them being too short. Or you could measure the width of your disc mount and of the threaded part of your caliper then allow for any washers you may need. and this will give you the minimum required shank length.
M6x18 should fit unless you have mega thick disc tabs
