Hope Tech Trials Disc Brake [Help]
dannytrialskid
EDIT:
When I pull in my brake, it varies. One time it will pull in about half way, then when you pump it, it will barely need to be pulled in. I have the reach and bite set to max, but sometimes it pulls in about half way.
The only reason I think it does this is because I got a puncture at a comp and sorted it out quickly, and didn't align my wheel correctly. Then when I got home I re-aligned it again. So I think that played around with it a bit.
If that makes sense.
It's a brand new brake, so it doesn't need bleeding.
Why is this?
Cheers, Danny.
Edited by dannytrialskid
