Hs11 Leaking
BradJohnson
wondering if anyone can help, i have a 2011 magura hs11 and it leaks from the lever,
i have took it all apart and everything looks fine,
but i noticed there was grease on the piston, if i put more grease on the piston and inside of the lever body will this stop the leak or will, i need a new piston or seal.
Thanks, Brad.
