Help Me!
jacksnell95
or go to your local ally welder and get him to weld a metal rod to the bolt and get some vice grips on the end of it....i did it
with a stuck cranks bolt, and the welder welded a nut onto the bolt and i now have a nice crank bolt
get a 4mm drill bit and drill into the bolt a good 3quarters of a centimetre, once you've done that get a t25 torx bit and hammer it into the hole you drilled (hammer the shit out of it and make sure its right in there), then simply undo the bolt!
i do this most days at work on customers bike's and it works a treat!
obviously replace the bolt afterwards :lol:
  • Like 1
ok that sounds the best idea :) thnx :)
