Joshm1991 Posted July 15, 2011 Report Share Posted July 15, 2011 Hi I have a MAD Phase 1.2 and I'm wanting to upgrade the hubs on it!! Now I've been told that Hope Pro 2 hubs are pretty good and I've found some front and rear ones that have the disk brake mounts on them. What I want to know is can I use them as standard hubs without having to mount a disc brake on my bike?? I have HS33's on my bike so obviously I'm wanting to keep them!! Would I still work if I used my rim brake rim on the hubs?? Cheers Joosh Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 15, 2011 Report Share Posted July 15, 2011 Yeah they'll work fine, just comes down to whether you'll wanna go front freewheel in the future or not Quote Link to comment Share on other sites More sharing options...
old'scoolfool Posted July 15, 2011 Report Share Posted July 15, 2011 all pro 2's have disc mounts you have both options with disc hubs where as with non disc hub you obviously cant have disc brakes should you want them in the future. imo if you only ever plan on using mags why have the extra weight of pro2's if your not using discs and dont plan on doing so its alot of unneccecsary weight i know what weight weenis are like Quote Link to comment Share on other sites More sharing options...
Joshm1991 Posted July 15, 2011 Author Report Share Posted July 15, 2011 (edited) Alrighty then.. Just I found some hopefully cheap front and rear hubs but I saw they had the dish mounts on and got a bit worried!! What would be the best alterative if I wanted to use just the maguras but wanted to keep it cheap?? Joosh Edited July 15, 2011 by Joshm1991 Quote Link to comment Share on other sites More sharing options...
old'scoolfool Posted July 15, 2011 Report Share Posted July 15, 2011 (edited) Alrighty then.. Just I found some hopefully cheap front and rear hubs but I saw they had the dish mounts on and got a bit worried!! What would be the best alterative if I wanted to use just the maguras but wanted to keep it cheap?? Joosh how cheap is cheap? and is it the pro 2 trials rear or just the standard? if your not bothered about he extra weight go for it there really good hubs Edited July 15, 2011 by old'scoolfool Quote Link to comment Share on other sites More sharing options...
