Chainstay Length.... How To Increase?
Alex Dark
Hey there, quite happy with my z3r at the moment, but just wondering if there's a good way of increasing the CS length at all? Maybe similar to the new echo mk1 frames, I think this would make it a bit less twitchy than it is currently.
Using 16:14 at the moment, which gives me 375mm ( or technically 374.7 ? ) Id like to increase it to around 383/5mm.
One whole link increases chain length by about 25mm I think, so one half link must increase it by about 12.5ish. Only problem is I need about 6mm, any ideas?
Also, are there any half-links worth bothering with?
half link is 12mm long so it´s increase chainstay leght by around 6mm (Y)(because of that your chain is going from freewheel to back and from back to freewheel again if you know what I want to say. :turned:
Edited by AndrewG
I'm have good luck with the odyessy blue bird chain.it has one halflink riveted on.
I've been trying to snap this chain and no dice yet.
I'm a big guy and shred cool chains,so this ones worth considering. It's basically a kmc 510hx just with a half link
Ah beauty was hoping someone was going to say that! Couldn't see it in my head for some reason...
Any recommendations for one single half link? Apart from the try-all one on tarty, ill see what else there is first before dropping £5 on one link!
  • 2 weeks later...
