Bb7 Rotor Hits The Caliper
Canardweb
Hello, yesterday I received my BB7 disc brake (203 mm) and my trialtech forks. I used a Hope F adapter (tarty helped me to choose as I didn't know which one to take) to mount the brake onto the +20 IS disc brake mount the Trialtech fork has.
When I had finished building the caliper on the fork I noticed the rotor was hitting the caliper and rubbing really hard and that made the wheel impossible to turn. I have tried both supplied adapters and the Hope one but it still rubbed really hard!!!! I filed it and it solved the problem but is this a common problem? Have I done something wrong?
Thanks.
caliper or adaptor ? if adaptor than it´s normal for 203mm discs so cut a little piece from adaptor. and if itś not adaptor than you should make a better pics to show what´s the problem (Y)
or place some washer under brake
Edited by AndrewG
The caliper hits so a washer won't change a thing.
I think I had this when I ran a BB7, I seem to remember I put another washer under the caliper to move it out 1mm or so, and the job was jobbed.
I concur, put a washer under the post .
He means a washer under the post mounts on the caliper :)
Thanks lads. I did yesterday but it still rubbed a fair bit...
The problem is due to adaptor F is the wrong one for your setup. Adaptor F is a 180 adaptor and then with the +20 makes 200 not 203.
The correct adaptor that you need is adaptor J which is 183 then with your +20 forks makes 203.
I have an almost identical setup to you with same forks rotor and BB7 but with the J adaptor and I have had no problems with rubbing.
Ha too late now anyway. Thanks man. I guess this is a common problem then.
As said in my earlyer post the problem is that the adptor is the wrong one for your setup.
So only common if people get the wrong adaptor.
How much? Less than 1.5mm and it will still rub.
Those supplied were like 1 mm so yes I needed more.
Wrong. First Tarty helped choose the adpater so I don't think they went wrong...
Second, I tried the supplied adapter too and it was rubbing just the same!
Cool, another washer will sort you out then :)
There is another adaptor available that is 1.5mm 'taller' (and therefore more 'correct'), but in reality it's not necessary when you can just add a couple of washers. We found the confusion caused by having different adaptors outweighed the 'problem' of adding the washers.
Without the extra spacers the adaptor is the wrong size, but as Adam has said that having loads of different adaptors can get confusing so just adding a couple of spacers to save all this explanation is much easier.
Also I take it that the standard adaptor is also 180 which means that you will get the same problem that can be solved with a couple of small spacers.
I understand. Thanks a lot for all these infos lads!
The brake is really awesome! Better than HS33 and Vees! It locks or modulates whether you want one or the other. Awesome!
Edited by Canardweb
