Does This Need Bleeding?
Dave Sutton
At first use an air compressor to clean the tubes. then try to bleed the brake system. If that doesn't work then try to changhe the seals or the whole brakeing system.
my 2011 hs11 is doing the same thing all the fluid ran out so i got it rebled and its all ran out again do i need a new seal
