piperfraz Posted July 12, 2011 Report Share Posted July 12, 2011 I'm having some trouble with my rear HS33. The TPA is fully out, the slaves are as far out as the clamps will allow but the left hand side pad still rubs. However the drive side pad has around 6mm space between the rim and pad. I have used the snail cams to move the wheel as far over to the drive side as possible but it isn't making much difference. Is there anything else that I can change? Fraser 1 Quote Link to comment Share on other sites More sharing options...
trials owns Posted July 12, 2011 Report Share Posted July 12, 2011 Undo the axel bolts and tap the left side forward Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 12, 2011 Report Share Posted July 12, 2011 If you've got a spoke key you could try dishing your wheel over more to your drive side? Quote Link to comment Share on other sites More sharing options...
piperfraz Posted July 12, 2011 Author Report Share Posted July 12, 2011 Undo the axel bolts and tap the left side forward I don't know how to as the snail cams are pushing the wheel as far to the drive side as possible... If you've got a spoke key you could try dishing your wheel over more to your drive side? What? 1 Quote Link to comment Share on other sites More sharing options...
Theta2 Posted July 12, 2011 Report Share Posted July 12, 2011 Basically it sounds like your rim is over to the non-drive side of your hub and needs moving towards the drive side, this can be done using a spoke key to loosen the non-drive side spoke and tighten the drive side. Hope this helps Quote Link to comment Share on other sites More sharing options...
piperfraz Posted July 12, 2011 Author Report Share Posted July 12, 2011 Sorted now Turns out it was something really simple and obvious 1 Quote Link to comment Share on other sites More sharing options...
Theta2 Posted July 12, 2011 Report Share Posted July 12, 2011 Sorted now Turns out it was something really simple and obvious Care to enlighten us? Quote Link to comment Share on other sites More sharing options...
piperfraz Posted July 12, 2011 Author Report Share Posted July 12, 2011 (edited) i just hadn't done the axle bolts up evenly haha! So after several hours of mucking about with my tpa, snail cams, clamps and pads, it turned out to be something as simple as that......cringe Edited July 12, 2011 by piperfraz 1 Quote Link to comment Share on other sites More sharing options...
