550D Test Clips
joakin
i thought you could get better quality with this camera no?
Is it rendered in 1280x720? cos' on my second monitor it has better quality than on my main which is 1920x1080 so i guess it was recorded/rendered in lower resolution and thats why its not that good on my main monitor...
anyways what resolution is that vid? :P
What did you use as editing sw? Vegas? Premiere? something else?? just check project/render properties... also be sure that it has rendering quality is set on Best
these are my settings for a intro on my channel iam doing right now
when you have you footage opend in a window and you select it you should be able to see (in bottom right corner) the width and height of the footage :)
post-24653-0-11098100-1310515790_thumb.j
Im using Vegas , and think thats where i made the mistake ! went to the options there, but think i screwd up somewhere :D
we are filming for a bigger and better movie now, so ill be sure to make it right the next time!
Thanks for the tips!They are much appreciated! :)
Edited by Georg
No problem :)
you know my problem is that my main screen is quite big and when i watch a video which is lower resolution it stretches the pixels so nomatter how good quality is that on my screen it doesnt look so good.
Id recommend rendering in 1920x1080 cos that could look well at both bigger and smaller screens
iam also thinking about getting 550D so i got a bit scared when i first watched it :D then i dragged it onto smaller screen and it was alot better ;)
No problem :)
hehe, might not be a bad idea.. rendered it in 1080 x 720 i think but i guess that i made a mistake with the bit and framerate, which made my vid in a more bad condition than the one lexen posted :)
Edited by Georg
