Repetitive Strain Injury
Pete.M
So it seems the only part of my body that hasn't got used to trials yet is my left hand. After every single ride it has this painful twinge that hurts for a good few hours. One thing I noticed when I started was that the bike's bars slope up slightly towards the ends, this puts extra pressure on the outer sides of my hands. I assume it is normal for bars to slope up like this? It feels awkward anyway. I am wondering if anyone here had the same issue when starting out? And are there any ways to help it? Should I try turn my bars round a bit to change the angle slightly?
It may go away after another few weeks riding but it could also get worse, just very annoying at the moment.
Also, is there an optimal angle to have the bars at or is that completely down to preference? I've been thinking the curve up in the bars should be around the same angle as the forks, if that makes any sense.
well what bars are they? most bars are a 9/10 degree rise. But it could well be that your hands haven't adapted to it yet.. stick with it and see how it goes :)
Not sure what bars they are to be honest, just the stock ones on a phase 1.1. I'll have to do just that I guess.
What part of your hand aches? Some people's wrists ache, and they find if they move the levers into a better position it stops.
The angle of the bars affects how your bike feels, particularly if they're riser bars. It might be worth playing with the angle to see if it lets off some strain, possibly leaning them back would help.
I can feel it when I move my wrist too but the pain is in the hand, like a strained ligament or tendon perhaps. Having to hold the rear brakes so hard is likely to be part of the cause, maybe that is something I will get used to soon. The levers feel like they are in the correct position but I might as well play around with that, and I think I might move the bars back slightly and see if there's a difference.
Cheers.
The reason for the upwards slope in bars is actually to make them line up better with your arms. Your arms leave your shoulders at an angle, and the bars should replicate that angle for comfort. Try rolling the bars back a bit and see what happens, and try the other bars you have as well - it's all about experimentation.
Do you have a brake booster on your rear brake? I recently bought a 1.1 and found that the seat stays flex like hell when you pull the brake. I'm gunna get a booster to stop the flex, hopefully resulting in not having to pull the brake lever so hard.
