Rourke Posted July 7, 2011 Report Share Posted July 7, 2011 So I got my heat sink yellows for my onza zoot 2010. The bike is running all stock parts in the brakes. So the problem I am running into is that there is to much rubber? When I put them on the Only way to make them work was to let the pads rub at a wierd angle. Is ther a way to make the pads rubb well? Is it bad that the pads are that way? Quote Link to comment Share on other sites More sharing options...
ogre Posted July 7, 2011 Report Share Posted July 7, 2011 have you had a play with the spacers? use less inbetween the pad backing and the caliper and more detween the caliper and the nut, it's hard to explain, you just need to fiddle about with it otherwise file or cut the pad down to get a nice square contact... Quote Link to comment Share on other sites More sharing options...
piperfraz Posted July 10, 2011 Report Share Posted July 10, 2011 Put a picture up of your setup 1 Quote Link to comment Share on other sites More sharing options...
