Revelation Posted July 3, 2011 Report Share Posted July 3, 2011 My rear brake locks well when the wheel is spinning forward, but when the wheel is spinnning backwards; it does not lock I am using Echo TR clamps which means the pads are square to the rim It's been this way for some time now, so If I'm landing a pedal gap, the rear brake would slip backwards Why is this? and How do I fix this? I do grind my rim with a cutting disk quite often. Quote Link to comment Share on other sites More sharing options...
jacksnell95 Posted July 4, 2011 Report Share Posted July 4, 2011 what pads are you using ? is there flex in the frame ? Quote Link to comment Share on other sites More sharing options...
BurlyBox Posted July 4, 2011 Report Share Posted July 4, 2011 and are the mounts level? this shows how to file down the mounts to make them level. Quote Link to comment Share on other sites More sharing options...
Revelation Posted July 5, 2011 Author Report Share Posted July 5, 2011 and are the mounts level? this shows how to file down the mounts to make them level. Big thanks mate! This is the one thing that I haven't done Quote Link to comment Share on other sites More sharing options...
