zoster Posted July 2, 2011 Report Share Posted July 2, 2011 i love slide outs! too bad i can't do them... for those that are confused, i am referring to the move done when riding fakie and you just turn your front end (without lifting it from the ground) in order to do a sliding 180. what happens is i turn the other way then i'm supposed to. (maybe i'll put a vid up with my failed attempts) anyway, any tips on doing these? thanks! PS: do you change the grip in any way when sliding out? Quote Link to comment Share on other sites More sharing options...
Ali C Posted July 2, 2011 Report Share Posted July 2, 2011 don't forget to keep pedaling backwards, lean back and slightly to one side (I slide to the left and lean to the right a tad) and turn the bars 90 or more. Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted July 2, 2011 Report Share Posted July 2, 2011 (edited) Unweight the front wheel quite abit and put your weight to the opposite side you are going you need to be going pretty fast aswell or you will just stop, its alot easier to practice on gravel. Edited July 2, 2011 by Milo123 Quote Link to comment Share on other sites More sharing options...
Sam T Posted July 2, 2011 Report Share Posted July 2, 2011 This guy is really good at them! Quote Link to comment Share on other sites More sharing options...
Ali C Posted July 2, 2011 Report Share Posted July 2, 2011 Karl is pretty good at them too as well as just riding in general. 2 Quote Link to comment Share on other sites More sharing options...
zoster Posted July 3, 2011 Author Report Share Posted July 3, 2011 thanks for the tips! i'll try them out and see if i manage to pull them out... Quote Link to comment Share on other sites More sharing options...
