Bottom Bracket/cranks Question
piperfraz
I was looking at some Trialtech ISIS cranks earlier, and was wondering if they would fit my BB. I don't know what kind it is, but i'm pretty sure it's the one my Onza T-Pro came with originally.
Any help much appreciated :)
Well, if your BB is ISIS then that's fine. If not, then no. I'd imagine the BB is square taper.
Okay, i'm gonna take the cranks off to have a look, but what are the differences between ISIS and square taper to look for?
Another question, the cranks come with a sprocket used on a 24"...Are the sprocket sizes different from mod and stock?
A square taper BB has 4 edges. An ISIS has several splined edges. Have a look at some pictures on tartybikes if you don't understand. Does your T-Pro not have a freewheel on the front?
Yeah it does, but the person selling the cranks has a sprocket and bash ring on it, would I be better with just the cranks?
Yes, if you ran a sprocket on the front you would need to run a freewheel or freehub on the rear. You'd probably be best sticking with your current ratio.
Take your crank off, is the bb axle square? it more than likely will be if its the original, so isis cranks wont fit
And stick with a freewheel on the front, if not you'll find yourself spending alot of money and its annoying to change all of it about
Edited by Kieran Morrison
