sebdandrea Posted June 28, 2011 Report Share Posted June 28, 2011 I have a onza tbird and was wondering if I could by any proper frame that all my bits would fit on to? I don't mind buyin a few things jst want a real frame! Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted June 28, 2011 Report Share Posted June 28, 2011 Should do! If you get a 'proper' frame, you'll need Magura to v-brake adapters, or a Magura/Echo rim brake. Quote Link to comment Share on other sites More sharing options...
sebdandrea Posted June 28, 2011 Author Report Share Posted June 28, 2011 Got hs33's dnt want v's. Proper frame I mean top tube is straight from headset to rear hub I had seat but removed it filled with beetle tape and covered with a sticker but it's jst not the same! Quote Link to comment Share on other sites More sharing options...
jacksnell95 Posted June 29, 2011 Report Share Posted June 29, 2011 if you t-bird is the model with a 20" back wheel so you would need to buy a 19" back wheel to fit the new frame but other than that everything will fit Quote Link to comment Share on other sites More sharing options...
sebdandrea Posted June 29, 2011 Author Report Share Posted June 29, 2011 if you t-bird is the model with a 20" back wheel so you would need to buy a 19" back wheel to fit the new frame but other than that everything will fit So the back wheel will be smaller than the front? Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted June 29, 2011 Report Share Posted June 29, 2011 Didn't all T-Birds have a 19'' wheel? If your tyre is marked something along the lines of 20x2.50 the back wheel will be fine. As for the brakes, I take it you have the silver T-bird? That came with HS33 mounts? Quote Link to comment Share on other sites More sharing options...
sebdandrea Posted June 30, 2011 Author Report Share Posted June 30, 2011 you man jst bought a mission frame here on fri hopefully. Thanks for the help chaps. Quote Link to comment Share on other sites More sharing options...
