Brettoll Posted June 27, 2011 Report Share Posted June 27, 2011 Ok I need some help with this as im usually a front vee / magura kind of guy. Recently purchased an avid juicy 3 disc, with post adaptor and a 203mm rotor.... Going to be changing my forks to a set of Try All Forx with a +20 dic tab on it. What I would like to know is whether I will need to decrease the post mount with the Try All Forx or is it easier just to get a smaller rotor?? Any help welcomed. Thanks, Brett Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted June 27, 2011 Report Share Posted June 27, 2011 If you where to use the adapter you have with your new forks you would need a 223mm rotor (LOL). If you wanted to use the 203mm rotor still, then you need a 180mm post mount to IS adaptor. If you wanted to use a 180mm rotor you need the "standard" 160mm post mount to IS adaptor. Quote Link to comment Share on other sites More sharing options...
Brettoll Posted June 27, 2011 Author Report Share Posted June 27, 2011 Yeah that's what I thought ha ha.. bit excessive Thanks for the response Quote Link to comment Share on other sites More sharing options...
