Can You Use The Onze Blade Wheelset With A Rim Brake?
Blake
Looking at the onza blade wheelset, it appears to have drilled holes in the sidewalls.
Does this mean that it wouldn't work with a rim brake?
Thanks.
Ive seen them ground and they seam to work fine.
All it means is you have a slightly smaller braking surface, and after several grinds the rim will be weaker than an equivalent wheel without holes.
