J.KYDD Posted June 21, 2011 Report Share Posted June 21, 2011 (edited) After snapping the Speedrace I was on the lookout for a new frame and Picked this up from Kevin at a great price. Geo: Wheelbase : 1085mm BB rise : +58mm Chainstay : 380mm Headangle : 72 Reach : 665mm Spec: Frame and Forks - Frame: Rockman Slate 3 - Forks: Rockman Spade 4 Bolt Wheels - Front hub: Echo TR / Ti bolts - Rear hub: Try-All 'H' 135 / Ti bolts - Front rim: Trialtech Square Hole - Rear rim: Rockman Single Wall - Spokes: Sapim double butted - Nipples: Viz! Alloy - Rim tape: Custom - Front tyre: Try-All Shift - Rear tyre: Try-All Sticky Light Brakes - Front brake: 2005 Magura HS33, 4 finger blade and metal TPA - Front pads: Rockman Blues - Brake clamps front: Magura, Echo SL C washers / Ti bolts - Rear brake: 2005 Magura HS33, 4 finger blade and metal TPA / alloy bolts - Rear pads: 'Real' Cousts - Brake clamps rear: 2 sets of Echo lowers ground down so no 'C' washers needed / Ti bolts Drivetrain - Cranks: 2010 Echo SL / Echo alloy bolts - Freewheel: Echo SL 18T - Chain: KMC 610HX - Rear Sprocket: Echo Ti 15T - Pedals: Try-All caged - Bottom bracket: Try-All - Bashring: Trialtech Steering - Headset: Neon - Stem: Rockman forged / All Ti bolts - Grips: Rockman foam - Handlebars: 08 Rage Bars - Weight: 8.66Kg Still have Try-All carbon bars, 28h radial non-disc front wheel, lighter tubes and some final Ti and alloy bolts to go! Comments Please! Edited June 22, 2011 by J.KYDD Quote Link to comment Share on other sites More sharing options...
Canardweb Posted June 21, 2011 Report Share Posted June 21, 2011 What is that rim tape on the rear wheel? Quote Link to comment Share on other sites More sharing options...
Maxx Posted June 21, 2011 Report Share Posted June 21, 2011 I suppose this : Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted June 21, 2011 Author Report Share Posted June 21, 2011 Duck Tape Yup Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted June 22, 2011 Report Share Posted June 22, 2011 Nice. Quote Link to comment Share on other sites More sharing options...
Canardweb Posted June 23, 2011 Report Share Posted June 23, 2011 Yup Cheers Quote Link to comment Share on other sites More sharing options...
Lewis Gething Posted June 23, 2011 Report Share Posted June 23, 2011 Looks sweeet as... Good job mate. Bet it rides nice. Quote Link to comment Share on other sites More sharing options...
