rocky111 Posted June 19, 2011 Report Share Posted June 19, 2011 I just got hold of a 06 Zoo Pitbull frame of ebay, all seems to be ok, but when I fitted Magur HS33 brakes on the back, I found that the cranks knock against the brakes every pedal stroke. I have adjusted the brakes in as far in as they can go without completely locking up the wheel but the cranks still hit them an ideas? has anyone else had a similar problem? Quote Link to comment Share on other sites More sharing options...
Rockman Posted June 19, 2011 Report Share Posted June 19, 2011 What cranks have you got ? Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 19, 2011 Report Share Posted June 19, 2011 If the cranks are only catching by a small amount then get a grinder or file and take a bit out the back edge of them. There's been quite a few people on here who've done it in on here and it won't make your cranks any weaker. Quote Link to comment Share on other sites More sharing options...
mrBENN Posted June 19, 2011 Report Share Posted June 19, 2011 (edited) Get a longer bottom bracket? That way it would take your cranks further out and away from the brake calipers. Edited June 19, 2011 by mrBENN Quote Link to comment Share on other sites More sharing options...
stephenmx50 Posted June 20, 2011 Report Share Posted June 20, 2011 I have a ZOO Piranha which i had the exact same problems on, if its just rubbing a little then as said above file/grind away a small amount on the back of the crank arms. Check your clearance when you put a new set of padds in as if you have an old set in there when you replace the pads the cylinders will be even further out. With mine i had to buy a new set of cranks, check the offset of your cranks, i brought a set of the trialtech sport cranks from tarty as they have one of the largest offsets around 34mm. New Bottom bracket might work but if the cotrrect size one is in there at present i would go down the new cranks road.. Hope this helps... Quote Link to comment Share on other sites More sharing options...
Revolver Posted June 21, 2011 Report Share Posted June 21, 2011 My middleburns do this on my because. Middleburns are bad for this, changing cranks is an option. If you're not using a 128mm BB, get one. Quote Link to comment Share on other sites More sharing options...
rocky111 Posted June 21, 2011 Author Report Share Posted June 21, 2011 thanks guys very helpful, yer I have middleburns I will have to look at getting a new set of cranks with a bigger offset. Quote Link to comment Share on other sites More sharing options...
