echoteam9484 Posted June 17, 2011 Report Share Posted June 17, 2011 As some of you may know some pads work better in plastic backings rather than plastic. so.... for heatsink yellows is the performance rate better in plastic or metal ? Quote Link to comment Share on other sites More sharing options...
dundy9 Posted June 17, 2011 Report Share Posted June 17, 2011 As some of you may know some pads work better in plastic backings rather than plastic. mix up of words but to answer your question heatsink pads work alot better int he metal backings, means a lot less flex and a stiffer less spongey feeling brake. Quote Link to comment Share on other sites More sharing options...
JD™ Posted June 17, 2011 Report Share Posted June 17, 2011 Check out a fairly recent topic by gary-mac to see peoples thoughts on side-by-side comparison. Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 17, 2011 Report Share Posted June 17, 2011 I'd say metal for rear, plastic for front. Gives you a tiny bit more moderation! Quote Link to comment Share on other sites More sharing options...
gary-mac Posted June 17, 2011 Report Share Posted June 17, 2011 Check out a fairly recent topic by gary-mac to see peoples thoughts on side-by-side comparison. Yip cheers dude, i actually need to up date the side by side comparisons. I tried new HSY pads in plastic backings for a week plus the saturday of the british cup and thought they were very good BUT i did change back to cnc HSY on the sat night ready for the british champs on the sunday and honestly there fantastic and alot better than plastic backing, bite is crazy and hold is mega. Not always the case with other compounds though. Quote Link to comment Share on other sites More sharing options...
Sam T Posted June 17, 2011 Report Share Posted June 17, 2011 Can't really fault my yellow. Amazing on a grind in the dry, and today i was riding in the wet. My rim was muddy, soaking wet and they still gave me confidence to keep riding! Quote Link to comment Share on other sites More sharing options...
aener Posted June 17, 2011 Report Share Posted June 17, 2011 Can't really fault my yellow. Amazing on a grind in the dry, and today i was riding in the wet. My rim was muddy, soaking wet and they still gave me confidence to keep riding! Did you even read the question? Plastics. Always. Never had metal backings be anything but detrimental - including Heatsink Yellows. Mind you, I can't set a brake up for toss as I'm fairly crap at maintenance. Quote Link to comment Share on other sites More sharing options...
Sam T Posted June 17, 2011 Report Share Posted June 17, 2011 Did you even read the question? Plastics. Always. Never had metal backings be anything but detrimental - including Heatsink Yellows. Mind you, I can't set a brake up for toss as I'm fairly crap at maintenance. Woops, forgot to include that they were in plastic backings. I sometime prefer plastic backings. If your brake is 100% set up with metal backings then it makes your brake pads wear at angles. Plastic on the other hand i dont tend to have too much of a problem with that. Quote Link to comment Share on other sites More sharing options...
