DeVal Posted June 8, 2011 Report Share Posted June 8, 2011 hi just got a pair of these and im trying 2 adjust the pad spacing but the screws on both of them are incredibly tight and without forcing them wont move (i dont wana force them) has anyone else had this issue with them? there is still plenty of thread to go into the level but just cant turn the damn things easily! Quote Link to comment Share on other sites More sharing options...
davidbarr Posted June 8, 2011 Report Share Posted June 8, 2011 What exactly are pad adjusters? Quote Link to comment Share on other sites More sharing options...
trials owns Posted June 8, 2011 Report Share Posted June 8, 2011 do u mean the twistable black tpa behind the lever? yeah they are stiff to start with and i had the same problem, just twist alittle harder and it should go! oh btw its best to set the brake up without using it. Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 8, 2011 Report Share Posted June 8, 2011 The tpa's are tight when new but they soon loosen up, though you shouldn't need to use the tpa to set the brake up! Quote Link to comment Share on other sites More sharing options...
Sam T Posted June 8, 2011 Report Share Posted June 8, 2011 If you pull it out, you can slot a 5 mm allen key into it and turn it with that. 1 Quote Link to comment Share on other sites More sharing options...
DeVal Posted June 8, 2011 Author Report Share Posted June 8, 2011 thanks for the replys guys. im NOT setting the brake up with the adjusters! im just fiddling around so i know how much pad life i can get when my pads do wear down. TNN LGMS dont come cheap so the longer i can use them the better! although a bodge may be needed with my thin rims lol Quote Link to comment Share on other sites More sharing options...
DeVal Posted June 8, 2011 Author Report Share Posted June 8, 2011 right another question. when i shorten the hoses i wanted 2 check first that the bleed fittings are the same size as the old style? Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 9, 2011 Report Share Posted June 9, 2011 The one in the lever body isn't but if you do it right they shouldn't need bleeding after being shortened, just have to be really careful not to knock the hose after it's been cut so you don't lose any fluid! Quote Link to comment Share on other sites More sharing options...
DeVal Posted June 9, 2011 Author Report Share Posted June 9, 2011 right so can you get bleed fittings for the lever? i will have to bleed them at some point. may have to do my overfill trick on the back aswell. i like nice tight levels lol Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 9, 2011 Report Share Posted June 9, 2011 Sorry I missread that last post, I believe the bleed fittings are all the same as are the hose fittings except for the barbed fitting that goes into the lever blade! May be worth giving Tartybikes a call though just to be sure! Quote Link to comment Share on other sites More sharing options...
DeVal Posted June 9, 2011 Author Report Share Posted June 9, 2011 right ive looked more clodely at the level bleed port and i removed the little black cap but what now? there are no grub screms behind it? surely there is a bleed kit for this brake right? Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 9, 2011 Report Share Posted June 9, 2011 http://www.magura.com/uploads/media/downloads/FELGEN_2011_E_01.pdf Page 14 and 15 Quote Link to comment Share on other sites More sharing options...
DeVal Posted June 9, 2011 Author Report Share Posted June 9, 2011 ah you see it would help if i got a manual with the brakes! legend thanks! Quote Link to comment Share on other sites More sharing options...
isitafox Posted June 9, 2011 Report Share Posted June 9, 2011 No worries! Quote Link to comment Share on other sites More sharing options...
DeVal Posted June 9, 2011 Author Report Share Posted June 9, 2011 only issue i can see is that i only have one syringe. ill have to prop the back wheel up and fill it in reverse lol should still work though as long as the oil drains out of the highest point. Quote Link to comment Share on other sites More sharing options...
DeVal Posted June 9, 2011 Author Report Share Posted June 9, 2011 all sorted and fixed. end of discussion lol Quote Link to comment Share on other sites More sharing options...
