Bb Axle Spacing
DeVal
thsi mite have a realy simple obvious answer but can i simply knock a bb axle with a hammer to get an even amount of axle either side of the frame. just noticed mine is sticking out slightly more on one side and ive forgotten how 2 set them lol
its an isis axel btw
Nooooo, what BB is it? I'm guessing it's in your Limey3? What side if sticking out more? If it's the non-drive side its because you have a 73mm wide BB in a 68mm shell, so you need to take out the BB and fit a 2.5 mm spacer between the BB and the frame to even things out.
na its actually the drive side which has more. there's about 10mm difference at most. the bb was lined up correctly when first installed but i think i may have pulled it through when fitting crank arms.
the bb itself is a 24/7 darkangel (3 piece)
