03danpad Posted June 6, 2011 Report Share Posted June 6, 2011 Hey, Not sure if this has already been covered in another forum, apologies if it has. Basically, how do you correctly grind rims? I'm using the Onza DD7 rim brakes set up nicely now but just need a little more bite. If someone could point me in the right direction! Quote Link to comment Share on other sites More sharing options...
Revolver Posted June 6, 2011 Report Share Posted June 6, 2011 http://www.tartybikes.co.uk/media/guides/maintenance_rim_grinding/m2.html Not only is tartybikes basically the best place to get trials parts from... they also show you how to set your bike up. Quote Link to comment Share on other sites More sharing options...
03danpad Posted June 6, 2011 Author Report Share Posted June 6, 2011 Spot on, Thanks a lot! Quote Link to comment Share on other sites More sharing options...
Kwizera Simon Posted June 7, 2011 Report Share Posted June 7, 2011 Just make sure that you apply the same pressure all the way around the rim. So you don't end up with a wavy breaking surface. Quote Link to comment Share on other sites More sharing options...
rogerb.23 Posted June 7, 2011 Report Share Posted June 7, 2011 thanks for the info Quote Link to comment Share on other sites More sharing options...
