Confused About Brake Squeek.
skidmark
hi. when i grind my rim i grind from right to left. my brake squeek fades away after an hour or so, but it only fades when the wheel is spinning forwards, when the wheel is spinning backwards i get an awsome squeek.
am i grinding in the wrong direction?
Your pads are not set up square :)
  • Like 2
Do you grind from right to left when you turn wheel over? If so the grind will be opposite ways on the rim. Check the pads are square as suggested ;)
yes i do. i think i might do it differently next time.
i squared my pads earlier and its a bit better
