Grant-MacD Posted June 2, 2011 Report Share Posted June 2, 2011 Does anyone know how to remove and put in a TPA? I have no idea how to do it and it would be really helpful is someone told me how. Many thanks Grant. Quote Link to comment Share on other sites More sharing options...
murph82 Posted June 2, 2011 Report Share Posted June 2, 2011 Does anyone know how to remove and put in a TPA? I have no idea how to do it and it would be really helpful is someone told me how. Many thanks Grant. Is it slipping the threads or jammed? First remove the blade from the body,then just wind it in the + direction until it drops out,the wheel and 'bushing' bits will drop out. Reverse to refit. If its jammed then put the pin in a vice,tighten it up,then lift the lever away from the vice,put something over it to extend it if you need extra leverage. The tpa will be wrecked but if its jammed up its probably done for already? Quote Link to comment Share on other sites More sharing options...
Grant-MacD Posted June 2, 2011 Author Report Share Posted June 2, 2011 Is it slipping the threads or jammed? First remove the blade from the body,then just wind it in the + direction until it drops out,the wheel and 'bushing' bits will drop out. Reverse to refit. If its jammed then put the pin in a vice,tighten it up,then lift the lever away from the vice,put something over it to extend it if you need extra leverage. The tpa will be wrecked but if its jammed up its probably done for already? Thanks i think thats helped. Quote Link to comment Share on other sites More sharing options...
