Carl-H Posted June 2, 2011 Report Share Posted June 2, 2011 My bike has HS33 slaves but a Julie lever like this one: http://www.chainreactioncycles.com/Models.aspx?ModelID=9437&utm_source=google&utm_medium=shopping&utm_campaign=Google-Products-UK I've looked at guides on bleeding and this doesn't have the bleed valve on the top like a hs33 lever. There's also not TPA but that doesn't bother me too much. I want a proper lever and master cylinder but funds don't allow yet lol. And ideas on how to bleed this setup? Wouldn't mind trying a bath bleed to see if I like water? I watched revolvers guide but im thinking this will be a little different? Carl Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted June 2, 2011 Report Share Posted June 2, 2011 By the looks of it, it works like a normal hydraulic system with a resivoir. So just fill the resivior, undo the bleed bolt on the slave, pull the lever in, tighten the bleed bolt, then release the lever. And repeat until u get a good bleed Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted June 2, 2011 Report Share Posted June 2, 2011 Bleed from the bottom up, with oil and a syringe. Take top cap off lever (T7 I think) to let fluid pour out, then re-fit cap. It's the 'wrong' lever for the slave cylinders but you should be able to make it work. Quote Link to comment Share on other sites More sharing options...
Carl-H Posted June 2, 2011 Author Report Share Posted June 2, 2011 Ahhh thanks, so I can do it either of those ways then. One thing, why is it just a bolt and not a bleed screw on the slave cylinder :@ spose I just need that bit of tube and the right connection thing from tartys? Think it's about £2? I dont mind just annoying waiting for delivery and last time I checked they were on order too. Not to worry though just wanted to bleed em and get em proper when I grind my rim today or tomorrow. Thanks guys Quote Link to comment Share on other sites More sharing options...
