piperfraz Posted May 31, 2011 Report Share Posted May 31, 2011 Hi, The other day I got some V!Z snail cams for my Onza T-Pro, because I can't be bothered going through more pairs of chain tugs. Anyway, because they are going on a T-Pro, I was told I would have to fit them on the outside of the frame. Is this correct? Can anyone tell me how I should fit them, or give me a link to a video that explains it? Cheers, Fraser Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted May 31, 2011 Report Share Posted May 31, 2011 http://www.tartybikes.co.uk/media/guides/maintenance_snail_cam_setup/m5.html Quote Link to comment Share on other sites More sharing options...
piperfraz Posted May 31, 2011 Author Report Share Posted May 31, 2011 http://www.tartybikes.co.uk/media/guides/maintenance_snail_cam_setup/m5.html Cheers, I have actually seen that before but thanks! However this only shows them once they are on the bike, so I'm wondering how I actually get them on? Thanks Quote Link to comment Share on other sites More sharing options...
Cap Posted May 31, 2011 Report Share Posted May 31, 2011 You should have a thread to fit a small bolt in the frame for the chaintug to stop up against, put a bolt in there leaving the head on the outside for the snail cam to press against, undo the wheel nut or bolt, remove the chain tugs and place the snail cam on the axle in the middle hole of the cam then refit the wheel nut/bolt, turn snail cam to tension, tighten wheel nut/bolt. Job done! 1 Quote Link to comment Share on other sites More sharing options...
