24" Street/trials Bike
Savagee
hello,
I've trialed a couple months but quited cause i got bored of it. So i have a bit experience with trial. (used to ride on a 26" koxx karbon)
Now i'm intrested in street/trial but i dunno which bike i should buy or is it cheaper to built one self?
I live in Belgium (soz for my english ;) ) so i can't buy a bike on this forum :( and there aren't any forums in belgium for street/trial.
my budget is maximum 1000 euro (is 850 pond) i prefer less :)
Also a mate is looking to begin with street/trial (no experience with trial or street) any suggestions for a bike?
Any information is welcome :)
thx
my mate has just bought a new zoot
its such a nice bike, its actually a piece of art
matt black and lime green <3
cost £440 from brand new, what ever that is in euro's?
but as ive started on a 20"
thx for the reply's
is there a big difference between the zoot bike and inspired element? (besides the v-brakes cause if i buy a zoot i'll put sd7 on it)
Is a hs33 for rear brake better then sd7?
And does those adapters fit with the thicker wheels?
440 pond is only 500 euro so it's cheap :D
as for the brake information, i dont really know enough about it
but as for the price of the zoot, it was cheap, on tarty bikes i think they are 530 or something
but just googled onza zoot
and it was 440 :)
does somehave have the answers to these questions?
The difference between the zoot and the element is the price they are built to, in theory you should get more bike with the element and in this case the theory is true as just about all the components of the element are a step above those of the zoot. With inspired and trialtech components the quality is unbeatable in my opinion, not that there is anything wrong with onza, the zoot is a truley great bike and you can't go far wrong with it. I do think it is a big step forward for off the peg trials bikes.
Previoulsy I would have said hs33 over sd7, however now I would argue that a well set up sd7 could produce a better brake.
If you mean adapters to convert vee mounts to hs33 then I do believe they should fit without any trouble (Y)
hmm thx for the information, i really dont know what to do :P
I want a descent bike cause i allready have some expierence with trial so i don't have to buy a new one after 2 months...
now i found a new cheap bike, any opinions on this bike?
Because 24" Simple Generalize street trials bike
- Frame: BECAUSE SIMPLE 24 street frame. (the frame is for hs33 brakes which i would buy cause i love those brakes :P)
- Fork: 26 Fork (Steel).
- Handlebar: BECAUSE 6061.
- Stem: BECAUSE 26.
- Headset: SCHWINN.
- BB: CH.
- Bush ring: BECAUSE.
- Cranks: BECAUSE 09 170 mm, square.
- Front Rim: BECAUSE 24"*46 mm.
- Rear Rim: BECAUSE 24*46 mm.
- Tyres: JinWancheng 24*2.4.
- Inner tubes: JinWancheng 24*2.35.
- Spokes: NEON stainless steel.
- Rim tapes: BECAUSE.
- Front Brake: Avid BB5 mechanical disc brake.
- Rear Brake: WINZIP V brake.
- Brake levers: BECAUSE.
- Convert-V: NEON 09.
- Grips: NEON.
- Front hub: QUANDO disc.
- Rear hub: JH.
- Cog: BECAUSE 14t.
- Chain: KMC710.
- Seat post clamp: BECAUSE.
- Seat Post: BECAUSE.
Geometry:
BB: 20 mm
Whellbase: 1040 mm
Head angle: 73
Rear hub width:136 mm
Chain stays: 380 mm
http://www.trialparts.net/cat.php?id=34 (scroll down)
thx
