Dj Freewheels And Gear Ratio
trials owns
yo,
this may sound gay but.........i wonna get a louder freewheel for my dirtjumper as my mate is bragging lol (due a new one anyway). so dont know much about 16t freewheels so what is good and loud??
my current ratio is 36:16, if i change it to a 18t freewheel (cough echo sl cough lol)will it still be a resonable gear ratio?
thanks
Edited by trials owns
If you want something really loud then you'd what to get a freehub (instead of a freewheel), the new Hope Pro2 Evo in particular, extremely loud but also very expensive. The Halo freehubs are quite loud too; best thing with a freehub is that you can just slide on whatever size sprocket that you want.
cheers i was concidering it, would make more sense. my frame is a 110mm hub spacing on the rear so i quess i would have to use a bmx one?
Ah I see, I know Profile make a freehub but not with splines on like the Pro2's but instead it has a single sprocket which you can pick the size you want (I think). I know Ns also make freehubs which a Dj and street specific but I'm not sure if they come in 110mm length.
Just had a look through them and it seems they are all 135mm. What Dj frame have you got as I thought 135mm rear axle was pretty much the standard, but I may have been wrong.
Saracen amplitude (one of the older ones) (Y)
What size dropouts do you have? 14mm or 10mm, be careful there too.
will have a look when i go out :)
