Kieran Morrison Posted May 28, 2011 Report Share Posted May 28, 2011 Right, i move my wheel until my chain is tight and then i tighten the bolts as hard as possible. Then i set the brake up until its 2 mm or so away from the rim... it doesnt rub at all, then i get on the bike, go on the back wheel and it starts rubbing - the wheel had moved? what could be the problem? Quote Link to comment Share on other sites More sharing options...
trials owns Posted May 28, 2011 Report Share Posted May 28, 2011 hub all smooth without any play? also lose spokes may cause this....... Quote Link to comment Share on other sites More sharing options...
Borat Posted May 28, 2011 Report Share Posted May 28, 2011 +Loose spokes, f**ked bearings or shitty nails cams moving. Check these. Quote Link to comment Share on other sites More sharing options...
davidbarr Posted May 28, 2011 Report Share Posted May 28, 2011 Buckled wheel? Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 28, 2011 Report Share Posted May 28, 2011 You recently had your frame painted, so it could be the hub/cams/bolts/whatever arent gripping the frame all that well because of it. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted May 28, 2011 Author Report Share Posted May 28, 2011 Buckled wheel? yeah but i move it so it doesnt rub even with the buckle, i think its the snail cams Quote Link to comment Share on other sites More sharing options...
davidbarr Posted May 28, 2011 Report Share Posted May 28, 2011 yeah but i move it so it doesnt rub even with the buckle, i think its the snail cams What cams are they? Maybe they're slipping.. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted May 28, 2011 Author Report Share Posted May 28, 2011 What cams are they? Maybe they're slipping.. Think they are smooth cams but ground notches in them, had a look at them they are screwed Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 28, 2011 Report Share Posted May 28, 2011 Get some echo trs, theyre the best ive used. Quote Link to comment Share on other sites More sharing options...
davidbarr Posted May 28, 2011 Report Share Posted May 28, 2011 (edited) Think they are smooth cams but ground notches in them, had a look at them they are screwed Echo Tr Cams That's what I run, and they've been great so far. Have notches in them already so won't slip. Edit: Beaten to it Edited May 28, 2011 by davidbarr Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted May 28, 2011 Author Report Share Posted May 28, 2011 Get some echo trs, theyre the best ive used. I need 2 12mm ones Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted May 28, 2011 Report Share Posted May 28, 2011 Sls then ? pretty sure there 12mm Quote Link to comment Share on other sites More sharing options...
