Stuck Freewheel.
Azarathal
Heya guys, freewheel s'ploded on Sunday, got my Echo SL today and after soaking the stuck freewheel over night in GT (Trying to permeate the threads) and having a 2ft extender bar + vice combo it refuses to budge.
Just spent the last of my money on the freewheel and a new(ish) frame so I can't afford a new crank and I especially don't want a pair of good condition trialtech cranks + bashring go to waste.
Any help?
I wouldn't assume it's stuck if you're using a 2ft extension to undo it. Try 4ft.
No idea where I'm going to get a 4ft pole wide enough but thanks anyway.
Vice & Mallet, job done.
2ft extension with some hench bloke trying to shock the freewheel off is going to be better than a mallet.
What freewheel is it your trying to get off?
Tensile96. The internals completely destroyed themselves and the lockring is stuck on as well.
We had alot of trouble remove my Tensile, even at the Universitys workshop which had access to lots of tools.
We ended up removing as mujch as the old freewheel as we could, which reveals 4 little flanges.
we then had to shove that in a lathe (on low gearing) for grip - normal vice kept slipping. This evntually gave way :S
edit: lots of we's ^ lol
Edited by dann2707
Alright guys I'll try find an even bigger extension bar. Shame theres no way to use my 6ft barbell :P
Try a short scaffold bar,the type used on the ends of each lift as a handrail? I know it means finding a nice scaffolder who'll lend a bar but that's the sort of think that will work. Are you putting the crank in the vice or the bb tool? Are you bolting the tool on through the spline so it cant slip?
