Duncy H Posted May 23, 2011 Report Share Posted May 23, 2011 I have previously run a full set of bottom magura mounts so that I could use my magura without the plastic washer cylinder things on the slaves, I had a thought that the only thing that differs between the top and bottom clamps is the small tabs it appears. If I were remove these tabs would they then effectively make the plastic washers redundant? Cheers for any pointers guys and gals Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted May 23, 2011 Report Share Posted May 23, 2011 Indeedy! Just file them off Quote Link to comment Share on other sites More sharing options...
Rex-Geo Posted May 24, 2011 Report Share Posted May 24, 2011 while we are talking about it what are the tabs for anyway?? i just bought some magura brake clamps a while back and the tabs are new to me since ive never seen them before, but because of them the bolts that came with it arnt long enough to fit all the way through into the frame Quote Link to comment Share on other sites More sharing options...
casualjoe Posted May 24, 2011 Report Share Posted May 24, 2011 The tabs are there so that when you bolt the clamps down they clamp the slave tighter. Quote Link to comment Share on other sites More sharing options...
