Ovalized Rim Repair
Dekes
A couple of years ago I bought 2 used planet X BMF, which are rebadged Alex DX32 rims, from a friend for £15. As my current try all rim is a bit worn, I wanted to lace one of those planet X rims onto my rear hub. I randomly took one and noticed it had a rather large difference in spoke tension at the seam-valve hole, compared to the perpendicular direction. I took a folding ruler and measured the difference, the diametre at the seam-valve hole was 5mm larger than in the perpendicular direction to that.
When measuring the other rim, there was only a 1mm difference in any direction. I tried sitting on the first one, but it didn't give in anything. Have you guys ever had this problem too and how did you fix it? Thanks.
Edited by Dekes
I had measured the rim unlaced, which is rather stupid and thus making this thread a bit obsolete. After lacing, the rim ended up just fine, except for a 2mm downward flatspot over 2 adjacent spokes, probably caused by the previous owner and not really mendable. This isn't really a big issue for a rear trials wheel anyway.
Edited by Dekes
