Drive Chain Problems..
Daborn Meister
Righto, my setup is a KO KM1 frame, Trialtech Race 128mm ISIS bottom bracket, Try-All 108.9 freewheel, Echo 6061 Forged cranks and a Try-All Symetrik bashring, here's my problem..
When i set it all up with the bashup, I tighten the bolts and eventually the freewheel is so close to the frame it grinds against it and stiffens up completely, I take the bashring off and the setup works fine? Are there any thinner bashrings, also do not suggest a plate as somebody cut the tabs off... Or any other solutions? I'm puzzled!
Grind down your bashring so it's a little thinner?
EDIT: Just had a quick look on Tarty.
The Tartybikes bashring is 1mm thinner than the Try-all one, so that could work too. If you look around I'm sure there will be thinner ones about.
Edited by AlexxRogers
