echoteam9484 Posted May 20, 2011 Report Share Posted May 20, 2011 all the echos on here are like 8 kg and the complete build from echo weights in at 10kg, Frame: Echo Pure 2011 - Forks: Echo SL, Disc Only Wheels - Front hub: Echo TR Disc - Rear hub: Echo TR 135mm - Front rim: Echo TR - Rear rim: Echo TR - Spokes: Plain Gauge - Rim tape: Echo, white - Inner tube (front): Echo Unboxed - Inner tube (rear): Echo Unboxed - Front tyre: Kenda Kinetics - Rear tyre: Kenda Kinetics Brakes - Front brake: Echo TR Hydraulic Disc, 180mm - Rear brake: Echo TR Hydraulic Rim Brake Drivetrain - Cranks: Echo TR, 170 ISIS - Freewheel: Echo SL 108, 18t - Chain: Echo Half-Link, 3/32" - Rear Sprocket: Echo TR 15T Screw On - Pedals: Echo TR Caged, Orange - Bottom bracket: Echo Urban ISIS, steel axle - Bashring: Echo Urban, Black Steering - Headset: Echo SL - Stem: Echo TR - Grips: Echo Rubber, Black - Handlebars: Echo TR whats making it this weight ? Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted May 20, 2011 Report Share Posted May 20, 2011 (edited) Tyres Rims No titanium or Alloy bolts Cranks Bashring Stem Edited May 20, 2011 by J.KYDD Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 20, 2011 Report Share Posted May 20, 2011 The tyres aren't super light, so they probably add 700g or so over light tyres. That puts it at 9.3kg, which is a pretty normal 'real' weight for a relatively light 26" bike. Quote Link to comment Share on other sites More sharing options...
jambo Posted May 20, 2011 Report Share Posted May 20, 2011 Got my echo sitting currently at 8.5kg Im not sure but if I changed the old echo pure v-forks, Got the ti bottom bracket, ti pedal spindles and carbon bars and changed out the standard tryall front rim id be looking at a stupid weight pretty close to 8kg. Quote Link to comment Share on other sites More sharing options...
