Hs33 Maximum Slave Cylinder Travel.
dann2707
Hey. So after doing a re-bleed on my HS33 this is the result of how far the pistons move on the slave cylinders. Looks like it's barely moving!?
Is this because of a shit bleed? Or is there anyway to maximise their travel. The TPA is all the way out and that blah.
Here is a pic that Ive just taken after the bleed, the lever is pulled all the way thanks to moma bear whilst I took the pic.
I think its about time I found a rear disk....
Edited by dann2707
  • Like 1
Due try these...
Press the lever with minimum piston move and watch when slave cylinder's piston move too. If it isn't an the same time. Rebleed the break.
ATAH lukas have right too :)
But IMHO you have air in lever, so you need only to move out air from there :)
