Brake Tension
Monkman
Having problems with my bmx brake its a evo 2 the bottom arm works perfectly and i can adjust the tension with ease..the problem is with the top arm. when i turn the cap to gain tension then tighten the allen key bolt the arm goes really stiff and as soon as i pull the lever theres a "Bang" and it looses ALL the tension....had it apart loads every thing is new and not damaged...
