Rourke Posted May 16, 2011 Report Share Posted May 16, 2011 I'm looking at one that is 11 kg Is that heavy? what does yours weigh? Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted May 16, 2011 Report Share Posted May 16, 2011 mines 10kgs, i think its pretty light. most are between 10 and 12 i think. Quote Link to comment Share on other sites More sharing options...
Rourke Posted May 16, 2011 Author Report Share Posted May 16, 2011 Thanks I picked uP an adamant mod, the one from webcyclery, it seemed like only 15lbs or 7 ish kg Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted May 16, 2011 Report Share Posted May 16, 2011 7kg? u sure? how much that cost? Quote Link to comment Share on other sites More sharing options...
max-t Posted May 16, 2011 Report Share Posted May 16, 2011 How heavy is a rock? Different builds will be different weights. Doubdtful that adamant was 7kg, it's a heavy frame on its own. What parts were on it? Quote Link to comment Share on other sites More sharing options...
Skoze Posted May 16, 2011 Report Share Posted May 16, 2011 My 609's about 11kgs, steel frame and fork and general "f**k you" to the weight weenies. Quote Link to comment Share on other sites More sharing options...
Carlperkins Posted May 16, 2011 Report Share Posted May 16, 2011 My 609's about 11kgs, steel frame and fork and general "f**k you" to the weight weenies. bahaha legend! Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted May 16, 2011 Report Share Posted May 16, 2011 The last time I weighed my brakeless inspired its was about 10.5kg. I don't have many trials specific parts on it most are mountain bike parts which are generally made for strength than low weight. I don't think many proper street bikes are that light really I don't think they need to be. Quote Link to comment Share on other sites More sharing options...
Topsy Posted May 16, 2011 Report Share Posted May 16, 2011 Well, if you've picked up a mod, why are you asking about street trial-weights? Quote Link to comment Share on other sites More sharing options...
Rourke Posted May 17, 2011 Author Report Share Posted May 17, 2011 The adamant includes.,. COMPLETE STOCK BIKES INCLUDE Echo Urban Disc Fork Echo TR Headset w/ 15mm of Spacers Kenda Kinetic 24x2.35 Tires Echo TR Fixed Rear Black Hub w/ 15T TR Cog & TR Chain Tensioner Echo TR Disc Black Front Hub Echo TR 24"Trials Rims DT Champion Black Spokes & Brass Black Nipples Echo White Rim Strips 18T White Industries Trials Freewheel Magura HS33 Rear Black Brake (or Louise Disc w/ 203 rotor) Echo SL 4-bolt Mounts/Clamps (on 4-bolt frames) Magura Louise Front Black Disc Brake & 160mm rotor Echo TR ISIS Front FW Crankset Moe Trials ISIS Bottom Bracket Echo Bash Ring Echo TR 25mm Riser Bar Moe Trials Stem KMC 810 Kool Chain Echo Black Trials Grips Echo Trials TR Pedals Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted May 17, 2011 Report Share Posted May 17, 2011 The adamant includes.,. COMPLETE STOCK BIKES INCLUDE Echo Urban Disc Fork Echo TR Headset w/ 15mm of Spacers Kenda Kinetic 24x2.35 Tires Echo TR Fixed Rear Black Hub w/ 15T TR Cog & TR Chain Tensioner Echo TR Disc Black Front Hub Echo TR 24"Trials Rims DT Champion Black Spokes & Brass Black Nipples Echo White Rim Strips 18T White Industries Trials Freewheel Magura HS33 Rear Black Brake (or Louise Disc w/ 203 rotor) Echo SL 4-bolt Mounts/Clamps (on 4-bolt frames) Magura Louise Front Black Disc Brake & 160mm rotor Echo TR ISIS Front FW Crankset Moe Trials ISIS Bottom Bracket Echo Bash Ring Echo TR 25mm Riser Bar Moe Trials Stem KMC 810 Kool Chain Echo Black Trials Grips Echo Trials TR Pedals Mod means 20'' That's got 24'' Rims. Quote Link to comment Share on other sites More sharing options...
Rourke Posted May 17, 2011 Author Report Share Posted May 17, 2011 My bad sorry. I thought mod was something else Quote Link to comment Share on other sites More sharing options...
JD™ Posted May 17, 2011 Report Share Posted May 17, 2011 I have naff all idea how much my street bike weighs, and that's kind of the point. It's a street bike. 1 Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted May 17, 2011 Report Share Posted May 17, 2011 Mine is currently hovering just above the 9Kg mark. Few more kit changes and i'll see it drop a good couple o' hundred grams below 9Kg Quote Link to comment Share on other sites More sharing options...
