Which Disc Brake Rotor Gives The Best Performance
Not sure on trials bikes but on motorbikes I know know what I like. My husaberg (supermoto) has a 6 pot beringer front caliper with a solid cast iron disc. Compared to other setups this one is amazing! One finger on the brake at 90 and your on the front wheel. Best brake I've ever used.
But the main reason for holes is to remove water I think? And to clean the pads in dirt/dust? In the wet the bringer has a delay of around a second ish as you get on the brake if you haven't used it for a few minutes. Quite strange to get used to.
But in trials you need a good hold, so I'm thinking a solid disc may not work as well then?
Iron discs are a he'll if a lot better than stainless though, apart from rusting but that's normally the sign of a good disc.
