How Much Would This Beast Go For?
Azarathal
Finally got around to putting pics of my comp up! RIP Z3(Nothing wrong with it, I just wanted a change.)
I hadn't fitted the chain in this picture :)
- Frame: Onza Comp
- Forks: Echo Lites
- Front wheel: Echo Urban rim, Pro-II Hub and Kenda SmallBlock8 tyre.
- Rear wheel: Trialtech reinforced(drilled) rim, Echo TR Hub and a Monty Eagle Claw tyre.
- Cranks: Trialtech, Trialtech half ring and an Echo SL FFW
- BB: Giggapipe
- Pedals: DMR V8s
- Stem: Echo Team
- Bars: Trialtech
- Front brake: Limited Monty edition Hope mono trials, 160mm rotor
- Rear brake: Limited Monty edition Hope mono trials, 160mm rotor
- Headset: Onza Mongo
- Grips: ODI Longnecks
Now has a front Hope rotor and rear try all rotor!
Edited by Azarathal
Loving the ghetto tensioner. Is it working well for you? I bodged one on for a night ride and it was very scary..
It works very well indeed. I would've kept it as just a plain spoke if the side plates didn't catch it and make it move about.
The roller itself is a tad too narrow for the chain so it doesn't even sit straight, better than nothing though.
Looks really nice!! whats the geo?
Wheelbase: 1000mm
BB: +60mm
Chainstay: 350mm
Weight: 1,9Kg
Mounts: HS33+Disc
Thinking about getting a new frame actually, I'd like something shorter for more streety moves whilst keeping a mid/high bb so I can still trials quite well.
Wheelbase: 1000mm
BB: +60mm
Chainstay: 350mm
Weight: 1,9Kg
Mounts: HS33+Disc
This is about as short as it gets, and the bb ain´t that high aswell!
You just need some riser bars and a higher stem or use some spacers.
Ahh well, I'm getting bored of the frame anyway.
Don't really want to faff about with stems and bars, plus my forks are already too short so spacers are out of the question :P
yeah there mine B) , don't see many of them around so thought they may be mine ^_^
I already had front and rear hopes but my front was the old style lever and these just look so pimp I had to get them :P
In tensioner related news, a local rider of mine (Kimosabi on the forums) has knocked this up for me, it goes around the chain stay and the bolt is to hope the roller in place (Once or twice a week it'll randomly bend into the wheel and snap the tensioner.
  • 3 weeks later...
  • 2 months later...
