Smiffy-23 Posted May 10, 2011 Report Share Posted May 10, 2011 (edited) hey guys me and my brother are after an avid front disc brake and rather than spend about £50 each just for the front disc.The cheapest i have seen them for is £45 for a set and was wondering if a rear disc brake will fit on the front and would i have to change the adaptor??? Edited May 10, 2011 by Smiffy-23 Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 10, 2011 Report Share Posted May 10, 2011 (edited) If I remember correctly the Avid disc brakes are universal and can be put on front or rear. Think you'll just need a new adaptor from somewhere like chainreaction. Edited May 10, 2011 by isitafox Quote Link to comment Share on other sites More sharing options...
smithy2050 Posted May 10, 2011 Report Share Posted May 10, 2011 do u mean like this http://www.chainreactioncycles.com/Models.aspx?ModelID=20304&utm_source=google&utm_medium=shopping&utm_campaign=Google-Products-UK Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 10, 2011 Report Share Posted May 10, 2011 Yeah just depends on what size front disc you want to run with the caliper Quote Link to comment Share on other sites More sharing options...
smithy2050 Posted May 10, 2011 Report Share Posted May 10, 2011 160mm discs Quote Link to comment Share on other sites More sharing options...
isitafox Posted May 10, 2011 Report Share Posted May 10, 2011 Yeah that would be the one then Quote Link to comment Share on other sites More sharing options...
smithy2050 Posted May 10, 2011 Report Share Posted May 10, 2011 ok then nice one thanks for the help Quote Link to comment Share on other sites More sharing options...
ogre Posted May 12, 2011 Report Share Posted May 12, 2011 cheaper here"type one" is the one you want Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted May 13, 2011 Report Share Posted May 13, 2011 Just to throw in a general bit of info too in case anyone ends up finding this in the search at a later date; Almost all rear disc calipers can be run on the front without the need for any other adaptors etc, but will require a 20mm larger rotor (ie a rear 160mm brake will be a 180mm on the front) Quote Link to comment Share on other sites More sharing options...
JD™ Posted May 13, 2011 Report Share Posted May 13, 2011 Just to throw in a general bit of info too in case anyone ends up finding this in the search at a later date; Almost all rear disc calipers can be run on the front without the need for any other adaptors etc, but will require a 20mm larger rotor (ie a rear 160mm brake will be a 180mm on the front) So you could run a 140mm rotor on the back if you used a 160mm front caliper? Or does it not work backwards? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted May 13, 2011 Report Share Posted May 13, 2011 Indeed you can. Quote Link to comment Share on other sites More sharing options...
