Brake Rotor Size Upgrade
Eddyboy123
Hey everyone
I am looking at upgrading the size of the disk brakes on my mountain bike (Mongoose Tyax Super '09).
This bike came with 160mm rotors so I am looking at upgrading to 203mm's at the lowest price possible (hopefully only needing to buy adapters and rotors, not callipers). Already have a bent rotor so might aswell
What different adapters would I need to buy and how do I need to fit them?
Front:
Back:
Back 2, please note the adapter already there:
Any help would be much appreciated
Thanks
James E
Edited by Eddyboy123
cheap rotors here... and cheap adapters here... why do you want bigger rotors? why 203mm? if you bent a 160, theres more chance of you hitting a 203mm rotor... they're heavier to. go for 180, most trials riders get the performance they need out of 180/185. 203 is excesive unless your riding DH and your having issues with over heating...
for the front you'll want a PM-PM F180 (or F200...)
for the year you'll want an IS-PM F180 (or 200)
thanks for the advice, probably will just go to a 180mm.
the reason is I want a bit more stopping power.
Edit: also does the shape of the rotor make much difference?
and for rear do you mean IS-PM R180 not F180?
I also wouldn't want to run 203 rotors with quick release axles!
The forces a disk brake has on an axle can cause it to move around in the drops outs. These forces would be much higher with a 203 rotor so I personally wouldn't run 203 rotors without bolt through axles!
I would personally go 180 front and 160 rear, this will be more than enough for everything apart from DH. Saying that, I ran that size rotor setup on Shimano XT brakes in the Alps for 1 week and didn't have any major braking issues!
Yeah thats what i was thinking now, just need to find some cheap rotors
Edit: i'm thinking these rotors:
http://www.readytoridecycles.co.uk/180mm-alligator-starlite-disc-brake-rotor-218-p.asp
  • 1 month later...
