Silent(-Ish) V-Brakes - Is It Possible?
zoster
Hey all !
I am currently using acor plazmatic pads(im guessing they're similar to the spanish flys and inspired pads) on the back of my 24". the grind on the rim was quite worn and the brake sounded like a "swoosh" (which was a good thing). it had bite but not so great hold so i put on a light grind and now it does have hold but it also squeaks awfully and i really hate if for going around town. I tried it with and without a booster and it's pretty much the same - lound as hell, so my question is: what is a decent combo for having a good brake without scaring people around the street? i am riding rear brake only at the moment so i need a decently sounding brake.
a guess would be plazmatics on smooth rim, but i don't know if i can go back to smooth when my rim is already ground, since it won't be perfectly flat and i think the pads won't work as well...
thanks for taking a look!
ps: i don't ride in the wet
If you're not riding in the wet, then just run a smooth rim and some black pads. Set up properly you're onto a winner - I ran front and rear Ultimates with the standard Avid Rim Wrangler pads and they were the best brakes ever! Silent over the year and a half I ran them, way more hold than any other brake I've used, and more than enough bite (more than I've got on the HS33/TNN setup I'm running on the Boxx despite the fact I now have a grind too!)
Worth at least considering. Who needs £30 brake pads when the standard cheap ones suit you better?! :P
You should be able to get the rim pretty much flat again with a file/couple of grades of sandpaper. Enough that general use will smooth it out the rest of the way at least (Y)
I ride medium grind on rock pad's And my brake holds very well and makes a swoosh noise that be it.
I used to run plaz pads on a light grind no tar again they were pretty quiet and hold well.
the rock pads are too expensive for my liking (they also seem to be quite wide which make the brake arms stick out which i really don't like).
i don't know if there are differences between the compounds of all these transparent plazmatic pads, but the ones that i have now don't hold well enough on a dead grind and on a fresh grind they are really loud. Maybe i'll try another brand to see if it makes any difference...
thanks for the reply!
i do have some wrangler pads, but at another location so i have to wait a bit to try them out, but will defiantly do.
until then, i put some shimano plain black pads on, with the rim still ground, and they fell great, they seem to hold great as well, but still squeal (less then the plaz ones, but loud enough to be disturbing).
I want to make sure i there isn't a way to get a decent sounding brake with a grind before i flatten the sidewalls (besides the rock pads that Seabasss mentioned earlier), so my question would be: can there be a setup that doesn't squeak on a ground rim? I don't mind that it squeaks when i pedal kick but i do mind if it does when i try to slow down while riding. If not, i'll put my faith in Luke and the wrangler pads...
PS: my frame is cromo, not alu, if it makes any difference
Use your feet.
i am, but sometimes you need the actual brake, and i try to block it directly and skid, so that it doesn't make a lot of noise (plus it's fun), but it still honks and makes people turn their heads
This is torture.
Dead grind and these pads, swoosh and hold.
so...thought to let you know i have swooshy brakes now, so hurray for that!
the "winners" are the jagwire basics comp pads. they did squeak at first, then i sanded them down a bit because they were too thick and felt too mushy, and they stopped making that annoying noise. this could be because the surface might not be completely flat anymore, but a bit convex. i'll see in time, after they wore down a bit more, if they start squeaking again (hopefully not), but atm they have a decent hold and they're silent, so i'm happy (still a bit mushy 'though).
i got my hands on the RW2s and i'll give them a try as well (without smoothing out the rim). i'll let you know how they work out...
I'd imagine those are relatively similar to the RW2s really - the Avid's are some pretty generic stuff in all honesty, just in a fairly tidy package.
It really is possible to get decent, usable performance from a cheap set of pads on a vee. It's not like running Magura Blacks, though certain postmen have shown those to be tolerable too :P
My SD7 with RW2s is silent and really good on the front :)
good to know :)
actually i think they are quite a different compound, softer and seem to have a different texture
(a friend uses these on a smooth rim and swears by them, he's actually the one that recommended these to me)
the basic shimano pads on the other hand are probably pretty much the same material and they felt great but did make noise...
here's my current build btw, if anyone is interested
